Equipo para DJ
Vendo equipo para es un sistema de dos lectoras de CD con MIXER de 4 canales tiene 5 meses de uso traido de USA esta como nuevo viene con case para guadarlo
Precio 280 MIL negociable escucho ofertas
ProThe ProdigyFX is the ultimate solution that will elevate your performance to the next level. It’s loaded with features you need and want including a wide array of DSP effects with parameter controls, master tempo, sampler, hot cues, integrated fader start, three-band EQ on every channel with kill switches, 3 MIC inputs with dedicated DSP reverb, dual rail Accutrack™ VCA crossfader, crossfader curve control, seamless loop, effects loop and CD direct outputs and mixer inputs for use with Serato Scratch Live, Synchroscience TORQ, Traktor Scratch and all other time coded systems.
Revolutionary All-in-one DJ Workstation
High Performance 4-Channel VCA Mixer
Two Scratching CD/MP3 Players
Advanced Onboard DSP Effects
CD / MP3 Player Features
Plays all formats of CD, CDRW and MP3 files with full functionality
Dual mode high resolution touch sensitive jog wheel
Seamless loop with on-the-fly access to loop editing
Independent buffer memory anti-shock for each player
Pitch control & master tempo with up to +/- 100% shift range
Oversized blue LCD display with wide viewing angle and brightness control
True instant start for both CD and MP3 operations
Easy MP3 file search by folder, file name, title or artist
Onboard DSP effects with multi-mode scratching, auto and manual filter and phase shifting as well as flanger, echo, trans, pan, & reverse
User-friendly beat synchronization for DSP effects
Auto BPM or manual TAP tempo
Three hot cue points
Three independent memory banks can remember up to 1500 cue points and/or samples
Integrated fader start
Slot loading transports with blue LED illuminator
IPR – Independent Player Reset for each CD/MP3 player provides fail-safe disk jamming protection
Built-in memory to save settings (memory is upgradeable)
