Tengo a la venta una S-AFC II edicion negra, en excelente estado.
Aqui los specs:
Piggyback Fuel Computer
Modifies air-flow meter signal (pressure signal in some vehicles) to optimize fuel-air ratio; Vacuum Fluorescent Display (VFD).
The second-generation SAFC is a fuel computer that adjusts fuel/air ratio by modifying the air-flow meter/MAP sensor signal. The SAFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500 RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The SAFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %.
Nombre: post-26196-1254395765347_thumb.jpg
Visitas: 59
Tamaño: 13,6 KB
ID: 30785 Nombre:  apexi-safc2-1.jpg
Visitas: 48
Tamaño: 14,7 KBNombre:  apexi-safc2-2.jpg
Visitas: 47
Tamaño: 16,2 KBNombre:  apexi-safc2-3.jpg
Visitas: 47
Tamaño: 13,7 KBNombre:  apexi-safc2-4.jpg
Visitas: 49
Tamaño: 15,6 KB
Mas informacion 8720-1790
