Tema: Amplificadores- Subwoofers- otros Soundstream
    Avatar de crivarar
    Fecha de ingreso Oct 2010
    Mensajes 16
    Compañeros tengo lo siguiente a la venta todo nuevo en caja con Garantia... Todo Marca Soundstream.
    Subwoofers PXW-12/2------------ Precio 60.000
    T/S Specs PXW-10 PXW-10/2 PXW-12 PXW-12/2 PXW-15 PXW-15/2
    Fs (hz) 33.53 31.27 27.79 25.65 21.65 24.69
    Qms 7.265 6.847 4.728 6.920 3.837 7.072
    Vas (ft³) 1.355 1.376 3.041 2.479 9.119 5.812
    Cms (mm/n) 0.248 0.252 0.263 0.215 0.261 0.166
    Mms (g) 90.8 102.9 124.6 179.4 207.2 250.0
    Rms (kg/s) 2.632 2.951 4.602 4.179 7.346 5.483
    Xmax (mm) 11.10 11.50 10.10 13.80 10.50 13.60
    Xmech (mm) 16.65 17.25 20.70 20.70 20.40 20.40
    Dia (in²) 8.069 8.069 9.732 9.732 12.840 12.840
    Sd (in²) 52.00 52.00 75.00 75.00 129.00 129.00
    Vd (ft³) 0.019 0.019 0.034 0.034 0.060 0.060
    Qes 0.970 0.861 0.840 0.769 0.585 0.753
    Re (Ohm) 7.2 4.0 7.2 4.0 7.2 4.0
    Z (Ohm) 8 4 8 4 8 4
    BL (Gauss) 11.92 9.69 13.65 12.26 18.62 14.35
    Pe (watts) 350 350 400 400 500 500
    Qts 0.856 0.765 0.714 0.692 0.508 0.681
    NO 0.144 0.134 0.213 0.149 0.433 0.318
    1w/1m SPL (dB) 83.61 83.28 85.30 83.75 88.38 87.04
    2.8v SPL (dB) 84.19 86.43 85.89 86.89 88.97 90.18
    VC Dia. (in) 2.0 2.0 2.0 2.0 2.5 2.5
    Impedance (Ohm) DVC 4 DVC 2 DVC 4 DVC 2 DVC 4 DVC 2
    M-vd (ft³) 0.100 0.100 0.125 0.125 0.150 0.150
    Amplificador
    SOUNDSTREAM LW1.400----------------- Precio 60.000
    ▪ MOSFET Pulse Widht Modulated Power Supply ▪ IDI Inteligent Distress Indicator (Short, Thermal & Overload Protection)
    ▪ Tri - Mode Capable (2 & 4 Ch. Models)
    ▪ Delayed On / Off Circuit
    ▪ 10 - 35KHz Frequency Response (A/B Models)
    ▪ 0.02% Total Harmonic Distortion
    ▪ > 250 Damping Factor
    ▪ 200mV - 6V Input Sensitivity
    ▪ 0,6 12dB 50Hz Bass Boost
    ▪ 12dB 35Hz Subsonic Filter (1ch, models)
    ▪ Input Selection (4 ch. models)
    ▪ High Level Input
    ▪ Pre - Amp Output (1ch Models)
    ▪ 180 Phase Shift (1 Ch models)
    ▪ Direct Wire 4 ga. Power, 8 ga. Speaker Terminals
    ▪ RMS @ 4 Ohm : 1 x 200
    ▪ RMS @ 2 Ohm : 1 x 400
    ▪ Channel 1 & 2 12dB LPF : 45 - 450Hz
    Tweeters TWS.4 ------------------------- Precio 12.000
    Tantalum 2-way mount tweeter
    Polished aluminum housing
    12 dB In-Line Crossover Network
    Backed by one year manufacturer waranty
    Rated Input Power: 110W
    Impedance: 4ohm
    Freq. Resp. 5KHZ-25KHZ SPL 95dB
    Cualquier Consulta por mp..... o al correo [email protected]
    Avatar de crivarar
    Mensajes 16
    Sigue en venta...!
    Avatar de RCalde
    Ubicación Costa Rica
    Mensajes 5.639
    Mae esa planta es puenteable? tiene filtro para bajos? para agudos? Tiene entradas HIGH INPUT LEVEL?
    Avatar de crivarar
    Mensajes 16
    Si mae viene con el filtro para bajos y agudos, tambien tienen la opcion HIGH INPUT LEVEL.... y este amplificador es de un solo canal... no es puenteable.... si de verdad esta interesado podemos mejorar el precio.....!
    Avatar de alfaro_acm
    Fecha de ingreso Jul 2011
    Edad 29
    Mensajes 15
    los twetters estan nuevos???
    Avatar de crivarar
    Mensajes 16
    si compañero todo esta nuevo en su caja original.......
  1. Par de plantas (amplificadores)
    Por allenh en el foro Articulos Electronicos
    Último mensaje: 18 June 2011, 03:22 PM
  2. Plantas/ Amplificadores
    Por YOGI en el foro Accesorios, Audio y Video
    Último mensaje: 17 June 2011, 12:02 PM
  3. Bajos Soundstream 12 pulgadas y planta Soundstream Picasso
    Por Gabriel Gato en el foro Articulos Electronicos
    Último mensaje: 29 August 2010, 07:07 PM
  4. Subwoofers Dual y amplicador soundstream
    Por epaez en el foro Articulos Electronicos
    Último mensaje: 4 August 2010, 12:57 PM
  5. Amplificadores -MA Audio
    Por rolla90 en el foro Accesorios, Audio y Video
    Último mensaje: 4 December 2009, 07:56 PM
soundstream pxw-12 foro
distribuidor soundstream costa rica
informacion de amplificadores soundstream
soundstream lw1 400
planta soundstream costa rica
sound stream precios
planta soundstream
amplificador soundstream III
subwoofer pxw - 15
imagenes de amplificador soundstreamdistribora sounstream en costa rica plantas amplificadoras venta en costa ricasoundstream costa ricaplanta soundstream lw1.400distribuidores soundstream en costa rica
