Tema: Interfaz de Audio >> Estudio de Grabacion
    Avatar de Gordooo
    Fecha de ingreso Aug 2008
    Edad 29
    Mensajes 185
    Buenas Gente, habia copmprado esta interfaz (Tascam US 1641) para un proyecto pero dsps me salio otra oportunidad y nunca la use, esta completamente nueva en caja y manuales, solamente la probe y funciona en todas!. La bichilla vale nueva $399 (cerca de 200 000 colones), la estoy dejando en 160 000 colones y se escuchan ofertas razonables.
    Precio: 160 000 colones (negociables)
    Cel: 8838 3407 (si no contesto por msj y les devuelvo la llamada)
    Aca les dejo el link de la compra y cierta especificaciones:
    http://www.musiciansfriend.com/pro-audio/tascam-us-1641-usb-2.0-audio-midi-computer-interface
    The fast, flexible, and affordable center of your computer music setup.
    The 16-channel TASCAM US-1641 MIDI-enabled interface is one of your best choices for getting audio into your computer properly. Equipped with USB 2.0 and enough I/O to record your entire band, the US-1641 audio interface is always ready when you lay down some tracks. Use it to capture live performances, like the fruit of your church choir's hard work. 16 inputs plus and 4 outputs offer enough channels to give every instrument and voice a chance to shine. TASCAM even includes Cubase LE Version 5 with the US-1641 for enough state-of-the art recording power to get the mix just right.
    Small enough to fit in a single rack space, the TASCAM US-1641 interface is ideal for both studio and portable computer recording. Since the mic and line inputs are on the front panel, there's no need for crawling behind a rack to get going. The rear panel is armed with 4 balanced line inputs for interfacing with synths, effects, mic preamps, or anything with a line level out. With the TASCAM US-1641 you also get up to 96kHz/24-bit audio resolution without having to lower the input/output count. The US-1641 interface's zero-latency monitoring prevents distracting delays for your performers during recording.
    Naturally, the TASCAM US-1641 is ASIO, GSIF2, and CoreAudio compatible for use with Logic Pro, Digital Performer, Cubase, SONAR, Nuendo, Final Cut Pro, Soundtrack, Vegas, Live, GigaStudio, and most other audio recording software.
    Features
    • 16 inputs and 4 outputs
    • 8 mic/line inputs with phantom power on front panel
    • Lets you record 10 simultaneous inputs
    • Two 1/4" balanced line/instrument inputs on front
    • 4 balanced line inputs on rear panel
    • Stereo S/PDIF digital I/O
    • 16-channel MIDI I/O
    • Separate monitor and headphone level controls
    • Zero-latency hardware monitoring
    • USB 2.0 interface
    • Up to 96kHz/24-bit resolution without lowering input/output count
    • Includes Steinberg Cubase LE5
    • Built-in power supply with an IEC connector
    • Compatibility with ASIO, GSIF2, CoreAudio Logic Pro, Digital Performer, Cubase, SONAR, Nuendo, Final Cut Pro, Vegas, Soundtrack, Live, GigaStudio, and more.
    G
    racias y Saludos
    Avatar de Gordooo
    Edad 29
    Mensajes 185
    UP! Se escuchan ofertas!!
    Avatar de Gordooo
    Edad 29
    Mensajes 185
    140 000!!!! Quien dijo yo??
    Avatar de dubua
    Fecha de ingreso Apr 2012
    Mensajes 2
    te la cambio por una camara de video ?? benq full Hd con el tripode
    Avatar de Gordooo
    Edad 29
    Mensajes 185
    Que modelo es?
    Avatar de dubua
    Mensajes 2
    es uan benq dv m 22
  1. Grabación de videos
    Por Lizano.com en el foro Zona Chat
    Último mensaje: 21 February 2012, 04:56 PM
  2. Paran la grabacion de Choriceros........
    Por Pedromz en el foro Zona Chat
    Último mensaje: 15 September 2010, 02:03 AM
  3. Interfaz Firewire 400 / 1394
    Por Drag en el foro Hardware
    Último mensaje: 19 October 2009, 06:07 PM
  4. Estudio SUGEF
    Por Dany FX16 en el foro Archivo 2002 - 2011
    Respuestas: 33
    Último mensaje: 8 September 2009, 01:00 PM
  5. TARJETA DE SONIDO PARA ESTUDIO DE GRABACIÓN
    Por edtower en el foro Archivo 2002 - 2011
    Último mensaje: 12 December 2008, 10:08 AM
