Tema: 2008 Ducati Monster 696
    Avatar de RicardoRJL1
    Fecha de ingreso Oct 2006
    Mensajes 4.949
    Ride the Monster 696 around your favourite downtown routes in relaxed style or, when the spirit moves you, unleash its dark side to deliver more naked performance than ever before.
    DESIGN
    Refined style and design are the clear motivations behind the new Monster and the continued perfection of the Desmo engine ensures that its ‘saint and sinner’ image will impress any rider. A comfortable and confidenceinspiring chassis combine with the famously smooth and powerful Ducati Ltwin engine to provide the most enjoyable riding experience. The balance of new technologies expressed in stylishly finished materials is shaped around the original cool Monster heritage.
    Maintaining its traditional Monster silhouette, the 696 now looks more muscular than ever. Its wide tank tapers to the thin waistline of a comfortable narrow seat ensuring sure-footed confidence when at the traffic lights. The large diameter Hybrid Trellis frame blends stylishly into an aluminium sub-frame and swingarm while minimalist instrumentation and simple controls at the front of the Monster contrast with twin, bold, Ducatistyle mufflers at the rear to enhance its urban-ready image.
    With a fuel tank form created with ingenious removable outer skins that enable quick and easy colour swaps, changing the personality of your Monster has never been easier. The quickly removable rear seat cover makes it even easier to completely colour coordinate and, when removed, reveals a place for your favourite passenger.
    The Monster cult
    The Monster is the original ‘naked’ motorcycle. Launched to rave reviews in the early ‘90s, it immediately created a devoted following and became a cult motorcycle. With its fully exposed engine and ‘less is more’ minimalist attitude, the Monster delivers style and real sport bike performance. It has defined the ‘naked’ class and become the bike of choice for top designers, Hollywood stars and Formula One racing drivers alike while creating a unique motorcycle lifestyle that is accessible to everyone.
    CHASSIS
    The 696 ergonomics have been improved with subtle but effective changes to the riding position. A shorter reach to the bars and a slightly lower, more forward footpeg position, together with the lowest seat height of any Ducati and a reduction in weight, empowers any rider to become the master of this Monster.
    The chassis of the new Monster is made up of a new Hybrid Trellis frame with larger diameter tubes directly inspired by the 2007 World MotoGP titlewinning Desmosedici GP7 machine. To this is attached a rear aluminium sub-frame.
    The front brake system is the envy of its class and becomes the new benchmark for the category with two 320mm discs and four-piston radial calipers.
    At the rear, the dual-sided aluminium swingarm draws inspiration from Ducati Corse’s finest racing products in this area. The instrumentation is now totally digital and continues the tradition of all Ducati’s latest-generation hypersport models, guaranteeing lightness, ease of use and a wealth of information.
    The new exhaust system stands out for its re-routed downpipes that now give the underside of the Monster a cleaner appearance and terminate with twin, bold Ducati-style mufflers. The headlamp unit is characterized by a new triple arc main beam, while the rear light uses modern LED technology. The unmistakable tank boasts ingenious removable outer skins which makes it easy to change the personality of the Monster 696. In line with the latest-generation Ducatis, the new Monster 696 has undergone a weight reduction of 5kg from the previous model and now becomes the lightest bike in its category (359lbs – 163 Kg).
    ENGINE
    The engine of the new 696 is an evolution of the previous 695 version. Measuring 696cc it boasts a series of updates and refinements.
    Power output gets a 9% boost to 80hp (59kW) and an 11% increase in torque to 50.6 lb-ft.
    This new engine continues to have the best horsepower per litre ratio of all Ducati’s air-cooled units, and it ensures a smooth and powerful delivery for a relaxed but thrilling ride in all conditions. This increase in power has been achieved by the introduction of new cylinder heads, which are now similar to the ones on the 1100 2V engine fitted to the Multistrada and Hypermotard. Bore and stroke remain identical to the previous 695 model at 88 x 57.2 mm, but the pistons and combustion chamber have been revised to optimize the fluid dynamics of the new ports.
    The camshafts now rotate on bearing surfaces directly in the cylinder head and are supported by means of oil pressure. The elimination of the bearings has enabled the weight of this unit to be reduced considerably and the layout simplified. Furthermore the cooling fins of the cylinders and the cylinder heads have a new shape, and an improved casting process allows them to be produced closer to one another so as to increase their number and improve thermal exchange. Like its predecessor, the new Monster 696 has an advanced APTC clutch, which makes down-shifting safe and helps keep the clutch lever action light and easy, especially in urban riding where frequent stops require high use.
    Like every bike in the new range, the Monster 696 also has a new scheduled maintenance programme that reduces costs for the customer.
    SPECIFICATIONS
    Engine
    Type: L twin cylinder, 2 valve per cylinder Desmodromic, air cooled
    Displacement: 696 cc
    Bore x Stroke: 88 x 57.2 mm
    Compression Ratio: 10.6:1
    Power: 58.8kW - 80 HP @ 9000 rpm
    Torque: 69 Nm - 7,0 Kgm @ 7750 rpm
    Fuel injection: Siemens electronic fuel injection, 45 mm throttle
    Exhaust: 2 aluminum mufflers
    Emissions: Euro 3
    Transmission
    Gearbox: 6-speed
    Ratio:
    * 1st 32/13,
    * 2nd 30/18,
    * 3rd 28/21,
    * 4th 26/23,
    * 5th 22/22,
    * 6th 24/26
    Primary drive: Straight cut gears; Ratio 1.85
    Final drive: Chain; Front sprocket 15; Rear sprocket 41
    Clutch: APTC wet multiplate with hydraulic control
    Chassis
    Frame: Tubular steel trellis frame
    Wheelbase: 57.2 in
    Rake: 24°
    Steering angle: 32°
    SoFront suspension: Showa 43 mm upside-down fork
    Front wheel travel: 4.7 in
    Front wheel: 3-spoke light alloy 3.50 x 17
    Front tyre: 120/60 ZR 17
    Rear suspension: Progressive linkage with preload and rebound Sachs adjustable monoshock
    Rear wheel travel: 5.8 in
    Rear wheel: 3-spoke light alloy 4.50 x 17
    Rear tyre: 160/60 ZR 17
    Front brake: 2 x 320 mm discs, 4-piston radial caliper
    Rear brake: 245 mm disc, 2-piston caliper
    Fuel tank capacity: 3.8 USgal (of which 0.9 USgal reserve)
    Dry weight: 359 lbs
    Seat height: 30.3 in
    Max height: 44.0 in
    Max length: 82.7 in
    Instruments: Digital unit displaying: Speedometer, rev counter, clock, scheduled maintenance warning, oil temperature, trip fuel, air temperature, lap time, warninglight for low oilpressure, fuel level, fuel reserve, neutral, turn signals, overrev,immobilizer.
    Warranty: 2 years unlimited mileage
    Avatar de CHRISTOPHER
    Mensajes 9.669
    Re: 2008 Ducati Monster 696
    chuzo de moto
    pero la verdad la linea de la ducatti monster no me gusta
    Avatar de p4u10
    Fecha de ingreso Mar 2007
    Ubicación I can hit 130km/h on 1st gear and I have 5 gears left... you do the math...
    Edad 39
    Mensajes 814
    Linda linea... lastima ese caballaje
    '05 Honda CBR 600rr Repsol Replica
    Powered by Two Brothers Racing
    Avatar de LUI
    LUI
    Fecha de ingreso Sep 2004
    Ubicación En la cámara de combustión de un V8...
    Mensajes 2.339
    A mí en lo personal... Ducatti es la moto q me gustaría tener... pero imagino q sólo x el hecho de ser italiana... debe ser sinónimo de repuestos astronómicamente caros....
    Avatar de laloguaro
    Ubicación ?????????
    Mensajes 748
    Iniciado por LUI
    +1,la unica vez q he pasado x donde venden las ducati creo q es en santa ana o escazu,se me caian las babas de ver esas naves,y me imagino lo q debe ser un repuesto de esas motos,xq no creo q haya muchas en CR,y diosguarde un choque en una de esas,yo q me quejaba cuando choque xq el arreglo de la mia me salio como en 200000,y con esa plata uno no le compra ni una direccional a una moto asi
    Avatar de DANNY...
    Mensajes 1.378
    No guta
    Avatar de MAKAROV
    Fecha de ingreso Apr 2008
    Mensajes 390
    la línea no me gusta y sobre todo no me gustan los silenciadores, me parecen sobredimensionados, lo demás si está mas o menos para mi gusto muy radical.
    Avatar de juliosc
    Ubicación San Carlos
    Mensajes 686
    Iniciado por p4u10
    Es una naked... Moto de paseo
  1. DUCATI Monster 620
    Por josvarve en el foro Motos Usadas
    Último mensaje: 25 August 2011, 04:21 PM
  2. Ducati Monster 796
    Por CHRISTOPHER en el foro Bikes & ATVs Review
    Último mensaje: 21 April 2010, 07:45 AM
  3. Motos Ducati de leyenda: Ducati 750SS
    Por JULIOWRC en el foro Bikes & ATVs Review
    Último mensaje: 19 May 2009, 08:44 AM
  4. Ducati Hypermotard
    Por heberca en el foro Bikes & ATVs Review
    Último mensaje: 19 May 2009, 07:51 AM
  5. ducati monster
    Por rolando peraza en el foro Bikes & ATVs Review
    Último mensaje: 29 December 2008, 08:03 AM
ducati monster costa rica
ducati monster precio costa rica
motos ducati monster costa rica
ducati costa rica
ducati monter cr
dokadi bike
kinds of ducatties
ducati monster foro costa rica
ducati monster 696 costa Rica
ducati naked costa rica
ducatties bike picture
ducati monster 696 imagenes
Docadi bike 390 cc
