Tema: Ducatti Monster 1100 2011 Diavel
Resultados 1 al 2 de 2
    Avatar de CHRISTOPHER
    Mensajes 9.669
    Ducat Diavel
    Make Model
    Ducati Diavel Year
    2011 Engine
    Liquid cooled, four stroke, 90°“L”twin cylinder, DOHC, desmodromic 4 valve per cylinder. Capacity
    1198.4 Bore x Stroke
    106 x 67.9mm
    Compression Ratio
    11.5:1
    Induction
    Mitsubishi electronic fuel injection system, Mikuni elliptical throttle bodies with RbW
    Exhaust
    Lightweight 2-1-2 system with catalytic converter and two lambda probes. Twin aluminium mufflers
    Ignition / Starting
    - / electric Clutch Light action, wet, multiplate clutch with hydraulic control. Self-servo action on drive, slipper action on over-run. Max Power
    162hp 119 kW @ 9500rpm
    Max Torque
    94lb-ft 127.5Nm @ 8000rpm
    Transmission / Drive
    6 Speed / chain
    Ratio
    1st 37/15 / 2nd 30/17 / 3rd 27/20 / 4th24/22 / 5th 23/24 / 6th 22/25 Wheelbase 1590mm / 62.6in Rake 28° Steering angle (total) 70° Frame Tubular steel Trellis frame
    Front Suspension
    Marzocchi 50mm fully adjustable usd forks, 120mm / 4.7in wheel travel.
    Rear Suspension
    Progressive linkage with fully adjustable Sachs monoshock. Aluminium single-sided swingarm, 120mm 4.7in wheel travel
    Front Brakes
    2 x 320mm semi-floating discs, radially mounted Monobloc Brembo callipers, 4-piston with ABS Rear Brakes
    Single 265mm disc, 2-piston floating calliper with ABS Front Tyre
    120/70 ZR 17
    Rear Tyre
    240/45 ZR17
    Seat Height 770 mm / 30.3in Dry-Weight
    210g / 463 lb
    Fuel Capacity
    17 Litres / 5.3 US gal Instruments Tank mounted instrumentation with TFT colour display: Gear selected, air temp, battery voltage, trips 1 & 2, fuel reserve trip, average and actual fuel consumption and speed, trip time, scheduled maintenance. Full status and/or management of Riding Modes, DTC, RbW and ABS.
    Ducati Diavel: The new shape of power and style
    The innovative new Ducati Diavel combines decades of twin-cylinder heritage and Italian style with a bold, world-beating technical confidence strong enough to extend the boundaries of motorcycle design.
    Custom shop beauty, state-of-the-art technology, innovative design and extraordinary riding pleasure are masterfully blended into the Diavel, a motorcycle destined to shape the future, a motorcycle built by people who have earned the right to change the rules.
    Built to have a commanding presence, though lightweight and agile like all Ducatis, the Diavel takes the man-motorcycle relationship to the next level in absolute comfort. For connoisseurs of technology, ABS, Ducati Traction Control and Ducati Riding Modes deliver a confidence-inspiring sophistication while stunning looks, 162hp and 207kg (456lb) of authentic Ducati performance drives a comfortable sport lifestyle that could only be dreamt of before.
    Merging the worlds of power and style has never been achieved with such convincing precision. A specially engineered 240 section rear tyre combined with famous Ducati chassis technology serves up mind-blowing handling and lean angles which defy the laws of physics, whether carving through curves on your favourite road or just riding out for a night on the town.
    The latest ground-breaking Ducati is available in two versions: The brand new Diavel and the flagship Diavel Carbon with a character-forming mix of aesthetic and performance components from carbon fibre bodywork to forged and specially machined Marchesini wheels.
    DESIGN Basic instincts
    The Diavel project was born when Ducati designers applied their wish-list of bike "basic instincts" to a blank canvas. With a "what if?" approach to creating a dream bike, they sketched inspiring shapes which became a lower and longer motorcycle.
    "The challenge of building a muscular silhouette over a pure-bred competition motor had to be met with determination and a delicate touch, and the result is a frontal area that looks like a power athlete on the starting blocks," explains the team at Ducati Design responsible for the project. "With the front wheel kept close to the Diavel's body and using the short tail of a sport bike, we were able to blend this muscular design with a chassis that matched."
    If the stance of a Streetfigher is that of "anger," the stance of the Diavel is that of readiness, dominance, and confidence bordering on superiority. With lateral radiators adding muscle to its broad "shoulders," which then taper down across the engine and into the belly-fairing with oil cooler, the athlete took shape.
    A massive 240 section rear tyre was a perfect example of how Diavel designers used a no-compromise attitude when applying their wish list of features. The sheer width of rubber communicates so much power and style that the R&D team vowed to find a way to make it handle - even if they knew the image would send a seismic shock through the industry.
    Ducati's philosophy for innovation has always been to push the boundaries of design in the name of exciting motorcycles. Sometimes "gut feelings" are what count, and having the strength to commit to them shows the kind of bravery that has guided Ducati to World Championships. The Diavel is a true Ducati, born from a passion for motorcycling and designed to deliver authentic Ducati performance in every respect.
    "Diavel"
    The name "Diavel" was inspired by the Bolognese dialect word for "devil". One day, early in the development process of the bike, the first prototype was assembled and wheeled out in front of a group of Ducati engineers and technicians who were viewing the complete motorcycle for the first time. One person looking from the rear of the bike saw its silhouette and exclaimed in Bolognese dialect: "Ignurant comm' al diavel!" Which means: "Evil, just like the devil!"
    Reminiscent of how the "Monster" was named almost 20 years ago, the Diavel now follows the same Bolognese tradition, shaping the future of motorcycling while staying faithful to its heritage.
    Rider and passenger comfort
    The Diavel's twin-level seat is wide, comfortable and beautifully shaped to fit the flowing lines of the machine and at 770mm (30.3in), has one of the lowest seat heights in the Ducati range. That low seating position, in addition to a low slung chassis set-up that weighs in at just 210kg (463lb) - 207kg (456lb) for the Diavel Carbon - enables the rider to get both feet on the ground for a sure-footed and confident stance. The seat also comes with a beautifully shaped and easily removable single seat cover, which is formed in carbon fibre on the Diavel Carbon.
    Passengers on the Diavel will appreciate the way the slender passenger footpegs ingeniously fold down from the rear sub-frame as well as the innovative, T-bar shaped grab-rail assembly, which slides out from the rear of the seat. Deployed from a mechanism under the seat, the grab-rail provides a comfortable and confidence-inspiring grip for the passenger, while the shape perfectly blends into the lines of the tail-piece when retracted. Both passenger-friendly features are crafted in forged aluminium and shot-peened for strength and uniform finish before being black anodised to become almost invisible when folded away.
    Lighting
    The Diavel uses two clear vertical strips of LED lighting to provide tail and brake light illumination as well as directional indicators. The strips follow the precise line of the under-seat panelling, providing great visibility of the rear-end while keeping the external lines of the bike clean. The front directional indicators are clear lens LED strips mounted vertically down the leading edge of the lateral radiator covers.
    The headlamp gives the Diavel immediate Ducati identity and is supported by an aluminium outer body. The light uses high and low beam double reflectors to illuminate the road ahead, in addition to incorporating a horizontal strip of LED positioning lights for optimum visibility.
    Innovative number plate mount
    Employing the double strip of multi-functional LEDs for the rear lighting of the Diavel required an innovative solution for the mounting of the number plate. The unique design uses mounts on the rear hub of the single-sided swingarm to extend an elegant and Ducati signature Trellis framework around the 240 section rear tyre, enabling a central mounting of the plate. The framework carries a hidden power feed to dedicated LED illumination for the number plate, eliminating any reliance on the main rear lights and creating a clean feature around the rear of the seat. This design solution represents the first of its kind and an example of the incredible attention to the Diavel's detail.
    Fuel tank and air Intakes
    The Diavel's 17l (4.5 gal US) fuel tank represents an integral part of the bike's overall styling. Its wide, long lines sweep down from the headlamp assembly into the seat and rear sub-frame to create a seamless profile. While the focal point of the tank is the high resolution display panel, the steel tank skin and well-sculpted knee panels add a solid feel to the Diavel and a high tech composite look to the Diavel Carbon.
    On each side of the front of the tank are massive air intakes formed in aluminium to feed the engine's large airbox. Their design is completely functional and contributes to the 162hp produced by the Diavel
    Testastretta 11° power plant.
    Controls
    The Diavel handlebar shape and arrangement leaves the rider feeling comfortable and in command. Wide, tapered section aluminium bars with new custom designed, integral brake and clutch master-cylinders by Brembo complete with milled reservoir tops, provide a clean and minimalist set-up, while stylish, forged-aluminium supported mirrors deliver a generous view to the rear.
    Switchgear control is taken care of by Ducati's latest and most minimalist design with slim-line bodies housing easy-to-use switches and buttons and a unique weapons-like "trigger catch" that slides down to cover the starter button when activating the kill-switch. While the indicator cancel button doubles as a scroll-and-select for fast and easy Riding Mode changes, switches above and below serve to navigate the new high-resolution display control panel.
    Colours
    The Diavel comes in traditional Ducati red with red frame and black wheels or a sophisticated pearl white silk and metallic black scheme with black frame and black wheels. The Diavel Carbon comes in stunning "red carbon" (gloss red over matte carbon weave) with red frame or "black carbon" (both gloss and matte carbon weave) with black frame. Both Diavel Carbon schemes roll on black wheels, turned and milled to expose the natural aluminium below.
    PERFORMANCE
    Diavel Testastretta 11° - ready for sport and cruise
    The heart of the Diavel is the Ducati Testastretta 11° - developed directly from the incredibly powerful, world-beating race engines of Ducati Corse. Ducati's Diavel Testastretta 11° harnesses the immense power of the Superbike engine and makes it smooth and adaptable, a massive step forward in balancing high-performance with an enjoyable ride.
    With its 162hp and colossal 94lb-ft (127.5Nm) of torque, the Diavel Testastretta 11° engine is all about authentic Ducati Desmodromic performance. The revised intake and exhaust ports combined with radical adjustment of the cam timing have enabled Ducati to achieve a fantastic torque curve at low rpm, which remains strong through a wider rev-range. The increase in bottom-end torque is managed by Ducati's Ride-by-Wire (RbW) system to considerably enhance the Diavel's effortless ridability, while ensuring plenty of power remains on tap for high-rpm riding.
    For an engine with brute power on tap when needed and smooth, user-friendliness available for an effortless and comfortable ride, Ducati revised the configuration of the cam timing with particular focus on the valve overlap angle. The overlap angle is defined as the interval of crankshaft rotation, measured in degrees, during which both the intake and exhaust valves are open at the same time. This overlap occurs between the end of the exhaust stroke and the start of the intake stroke. High performance engines, which are subject to compromising smoothness for extreme power delivery, use high values of this parameter in order to benefit from the pressure waves to improve engine performance by maximising volumetric efficiency.
    On the Testastretta 11° engine, this angle has been reduced from 41°, used in the Testastretta Evoluzione engine which powers the 1198, to 11°. As a result, the fresh inlet charge flow is less compromised by the exiting exhaust gases, resulting in a much smoother combustion in addition to improved fuel economy and lower exhaust emissions.
    The Diavel's gearbox uses high-strength materials to manage the increased power output and enhanced grip generated by the 240 section rear tyre, which also requires the use of a 16mm longer gearbox output shaft for drive chain routing.
    The Diavel Carbon comes in stunning "red carbon" (gloss red over matte carbon) with red frame or "black carbon" (both gloss and matte black carbon weave) with black frame. Both Diavel Carbon schemes roll on black wheels, turned and milled to expose the natural aluminium below.
    While carbon fibre is used for the tank panels, single-seat cover and front mudguard to reduce weight and apply a race-like feature that runs deep in the DNA of Ducati, a low friction diamond-like carbon finish gives the Marzocchi fork sliders a spectacular black finish as well as performance-enhancing action.
    Helping the Diavel Carbon to accelerate faster, stop sooner and change direction with even more agility is a valuable 5.5lb (2.5kg) saving of "unsprung weight" by using beautifully forged, lightweight Marchesini wheels. The wheels, which are finished in black, are machine-turned and milled for maximum weight reduction and intricately engineered decoration. The black disc carriers undergo a similar milling process to enhance the recess around the weight saving cut-outs, the natural aluminium colour contrasting effectively against the original black carrier.
    Mensajes 9.669
    Re: Ducatti Monster 1100 2011 Diavel
  1. Hyundai tucson 2011 vs kia sportage 2011 cual es mejor
    Por arturo hv en el foro Temas Generales
    Respuestas: 46
    Último mensaje: 17 March 2012, 10:03 AM
  2. VENDIDO hp tx 1100
    Por maqupa en el foro Computadoras
    Último mensaje: 4 July 2011, 08:21 PM
  3. Monster Jam 2011
    Por Acelera. en el foro Zona Chat
    Último mensaje: 4 May 2011, 02:50 PM
  4. CDI Suzuki Katana 1100 GS Año 87
    Por lobitodelmar en el foro Mecanica
    Último mensaje: 14 January 2010, 04:10 PM
  5. ** NOKIA 1100 10 MIL ... **
    Por Barquero en el foro Archivo 2002 - 2011
    Último mensaje: 18 January 2009, 07:53 PM
ducat
DUCATTI
ducatti picsmonster 1100 20112007 ducatti 1100 motorcycle linetail number plate not on the body bt lower on the tyreroyal enfield priceducati
