Tema: Monitor IPS Led de 24" HP Z24i
Resultados 1 al 3 de 3
    Avatar de suki
    Fecha de ingreso Oct 2006
    Ubicación "I thought I'd thought of everything..."
    Mensajes 2.134
    Buenas. Estoy vendiendo un monitor Led IPS de marca HP modelo Z24i con resolución de 1920x1200.
    El monitor se encuentra en perfecto estado con muy poco uso. Estoy pidiendo US$265,oo.
    Aquí están las specs. Interesados si gustan me envían MP. Saludos,
    HP Z Display Z24i 24-inch IPS LED Backlit Monitor (ENERGY STAR)(D7P53A8)| HP® United States
    Display specifications
    Display size (diagonal) 24" Aspect ratio Widescreen (16:10) Native resolution 1920 x 1200 Pixel pitch 0.27 mm Brightness 300 cd/m² Contrast ratio 1000:1 static
    5000000:1 dynamic View angle 178° horizontal
    178° vertical Response time 8 ms gray to gray Product color Black Tilt and swivel angle Tilt: -5 to +30°
    Swivel: ±45°
    Pivot rotation 90° Display features Plug and Play
    Anti-glare
    User programmable
    Language selection
    On-screen controls
    LED Backlights
    In plane switching Physical security Security Lock-Ready Connectivity
    Connectivity
    Input connector 1 VGA
    1 DisplayPort (with HDCP support)
    1 DVI-D (with HDCP support) Ports 5 USB 2.0 (one upstream, four downstream) Dimensions and weight
    Weight 15.35 lb (6.96 kg)
    (with stand) Product dimensions without stand (W x D x H) 22.02 x 2.54 x 14.37 in (55.94 x 6.45 x 36.5 cm) Product dimensions with stand (W x D x H) 22.02 x 9.37 x 20.67 in (55.94 x 23.79 x 52.5 cm) Power and operating requirements
    Power
    • Input voltage: 100 to 240 VAC
    Power consumption
    • 55 W (maximum)
    • 36 W (typical)
    • > 0.5 W (standby)
    Operating humidity range 20 to 80% RH Energy efficiency ENERGY STAR® qualified
    EPEAT® Gold Environmental Mercury-free display backlighting
    Arsenic-free display glass
    Low halogen
    Play with fire you must be mad, are you only Jack the lad?
    Avatar de suki
    Mensajes 2.134
    Siempre a la venta, nuevo precio especialísimo: $205,oo!
    Saludos,
    Avatar de RobertoAcuna
    Fecha de ingreso May 2011
    Ubicación Coronado
    Mensajes 2.273
    MP!
