Tema: Vendo MOBO AsRock N73V-S en perfectas condiciones
    Avatar de Chino316
    Mensajes 202
    Aqui las especificaciones
    Product Specifications
    General
    CPU - LGA 775 for Intel® Core™ 2 Extreme / Core™ 2 Quad / Core™ 2 Duo / Pentium® Dual Core / Celeron® Dual Core / Celeron®, supporting Penryn Quad Core Yorkfield and Dual Core Wolfdale processors
    - Supports FSB1333/1066/800/533 MHz
    - Supports Hyper-Threading Technology
    - Supports Untied Overclocking Technology
    - Supports EM64T CPU
    Chipset - NVIDIA® GeForce 7050 / nForce 610i
    Memory - 2 x DDR2 DIMM slots
    - Supports DDR2 800/667/533 non-ECC, un-buffered memory
    - Max. capacity of system memory: 16GB*
    *Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® XP and Windows® Vista™. For Windows® XP 64-bit and Windows® Vista™ 64-bit with 64-bit CPU, there is no such limitation.
    BIOS - 4Mb AMI BIOS
    - AMI Legal BIOS
    - Supports "Plug and Play"
    - ACPI 1.1 Compliance Wake Up Events
    - Supports jumperfree
    - SMBIOS 2.3.1 Support
    - Supports Smart BIOS
    Audio, Video and Networking
    Graphics - Integrated NVIDIA® GeForce 7050
    - DX9.0 VGA, Pixel Shader 3.0
    - Max. shared memory 256MB
    - Supports D-Sub with max. resolution up to 1920x1440 @ 60Hz
    Audio - 5.1 CH Windows® Vista™ Premium Level HD Audio (ALC662 Audio Codec)
    LAN - Realtek PHY RTL8201EL
    - Speed: 10/100 Ethernet
    - Supports Wake-On-LAN
    Expansion / Connectivity
    Slots - 1 x PCI Express x16 slot
    - 1 x PCI Express x1 slot
    - 2 x PCI slots
    Connector - 4 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1 and JBOD), NCQ, AHCI and "Hot Plug" functions
    - 1 x ATA133 IDE connector (supports 2 x IDE devices)
    - 1 x Floppy connector
    - 1 x Print port header
    - CPU/Chassis FAN connector
    - 24 pin ATX power connector
    - 4 pin 12V power connector
    - CD in header
    - Front panel audio connector
    - 2 x USB 2.0 headers (support 4 USB 2.0 ports)
    Rear Panel I/O I/O Panel
    - 1 x PS/2 Mouse Port
    - 1 x PS/2 Keyboard Port
    - 1 x Serial Port: COM1
    - 1 x VGA Port
    - 4 x Ready-to-Use USB 2.0 Ports
    - 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
    - HD Audio Jack: Line in / Front Speaker / Microphone
    Other Features / Miscellaneous
    Unique Feature - ASRock OC Tuner
    - Intelligent Energy Saver
    - Instant Boot
    - Hybrid Booster:
    - CPU Frequency Stepless Control
    - ASRock U-COP
    - Boot Failure Guard (B.F.G.)
    Support CD - Drivers, Utilities, AntiVirus Software (Trial Version)
    Accessories - Quick Installation Guide, Support CD, I/O Shield
    - ATA 133 Cable (optional)
    - 1 x SATA Data Cable (optional)
    - 1 x SATA 1 to 1 Power Cable (optional)
    Hardware Monitor - CPU Temperature Sensing
    - Chassis Temperature Sensing
    - CPU Fan Tachometer
    - Chassis Fan Tachometer
    - CPU Quiet Fan
    - Voltage Monitoring: +12V, +5V, +3.3V, CPU Vcore
    Form Factor - Micro ATX Form Factor: 9.6-in x 7.0-in, 24.4 cm x 17.8 cm
    OS - Microsoft® Windows® 7 / 7 64-bit / Vista™ / Vista™ 64-bit / XP / XP 64-bit compliant
    Certifications - FCC, CE
    Viene con 6 meses de garantia, tiene absolutamente todos componentes el precio es 45000 totalmente negociables
    Cualquier duda solo consulten
    Avatar de Chino316
    Mensajes 202
    Re: Vendo MOBO AsRock N73V-S en perfectas condiciones
    quien con la mobo???
    Avatar de Chino316
    Mensajes 202
    UP, recuerdo que el precio es totalmente negociable
    Avatar de Chino316
    Mensajes 202
    QUIEN CON LA MOBO, URGE VENDER YA QUE NO ME ESTA AGUANTANDO LA CONFIGURACION DE MI COMPU ASI QUE OFRESCAN LO QUE SEA NECESITO VENDERLA
    Avatar de Chino316
    Mensajes 202
    SE VA EN 40 PAPELES NEGOCIABLES
    Avatar de Chino316
    Mensajes 202
    QUIEN CON LA MOBO
    Avatar de Chino316
    Mensajes 202
    NADIE INTERESADO????
    Avatar de Chino316
    Mensajes 202
    QUIEN CON LA BICHILLA
  1. VENDIDO Nokia N8 - Menos de un año de uso, perfectas condiciones
    Por arkangel en el foro Celulares
    Último mensaje: 17 October 2011, 06:50 PM
  2. Vendo ATI 4850 XFX En perfectas condiciones..
    Por Chino316 en el foro Equipo de Computo
    Respuestas: 17
    Último mensaje: 3 January 2011, 12:18 PM
  3. Vendo fuente thermaltake en perfectas condiciones
    Por Chino316 en el foro Archivo 2002 - 2011
    Último mensaje: 24 September 2010, 11:46 PM
  4. Vendo Mobo ASRock G31M-S
    Por kol88 en el foro Archivo 2002 - 2011
    Último mensaje: 23 June 2009, 06:11 PM
  5. Vendo CPU en perfectas condiciones
    Por tatonavarro69 en el foro Archivo 2002 - 2011
    Último mensaje: 20 March 2009, 02:02 PM
