Tema: Busco case full tower
    Avatar de alonvalle17
    Mensajes 166
    Alguien con case full tower ?
    Avatar de kevinr
    Fecha de ingreso Nov 2007
    Edad 28
    Mensajes 7.101
    Como vas Alonso todo bien! Mira tengo este a la venta..
    Case Cooler Master Stacker 810 Full Tower 80 Mil
    Introduction
    Cooler Master went back to the drawing boards after introducing the CM Stacker a year ago, and we have managed to incorporate the essential features of a server from the existing CM-Stacker to create the powerful CM-Stacker 810. The CM-Stacker 810 supports up to 4 CPU motherboards ranging from Micro-ATX to full size Extended-ATX. Unique power supply cage re-design to fully support standard ATX or redundant power supplies. We maximized the airflow by reconstructing the motherboard tray to support two 120mm super silent exhaust fans. Back from the root, CM-Stacker 810 will continue to have the ability to utilize up to three 120mm fan from the 4-in-3 Device Modules. Most importantly, the CM-Stacker 810 maintained the spacious interior working space and expandability from the eleven 5.25” bays from the previous version to meet and expand your imagination. Once again, the CM-Stacker 810 will put Cooler Master one step ahead of our competitors.
    Features
    Expandability
    -Supports up to 11x 5.25” drive bays.
    -Moveable front I/O control panel with 6 x USB 2.0 connections.
    -Compatible with Micro-ATX, ATX, E-ATX 12"x13", W-ATX 13"x16"
    Cooling
    -Full Mesh front panel provides superior airflow; fully supports up to 3 x 120mm super silent fans.
    -2 x 120mm super silent exhaust fans.
    Assembly
    -Tool-free installation.
    -Spacious interior design to maximize the flexibility of installation process.
    Structural
    -Strengthened body structure with 1.00mm steel plates.
    -Superior mechanical design for greater stability.
    Specifications
    Available Color Silver, Black
    M/B Type Micro-ATX, ATX, E-ATX 12"x13", W-ATX 13"x16"
    Dimension (W / H / D) L584 x W227 x H536mm
    Material Aluminum Bezel, SECC Chassis
    3.5" Drive Bay 4 (Hidden) from 1 x 4-in-3 Device Module included; 1 x 3.5
    5.25" Drive Bay 11(Exposed)
    I/O Panel USB 2.0 x 6, Mic x1, SPK x1, IEEE 1394 x1(Support HD Audio)
    Cooling System One 120 X 120 X 25 mm Front Fan; 1200 rpm, 22 dBA (intake),
    Two 120 X 120 X 25 mm Rear Fan; 1200 rpm, 22 dBA (exhaust),
    One 80 X 80 X 25 mm Top Fan; 1800rpm 22dBA (exhaust)
    Weight Gross Weight: 17 kg; New Weight: 14.3 kg
    Power Supply Standard PS2 (option) ; EPS 12V Compatible (optional)
    Click here to view the original image of 800x880px.
    Avatar de diego9x
    Ubicación Santa Ana
    Mensajes 715
    Cooler Master HAF 912, lo pinté de negro mate adentro, 6 mese de uso con la caja... Deme 30.000
    Mensajes 166
    tuanis por las ofertas. podes poner fotillos del 912 ? es que quiero ver que abanicos son los que trae. tuanis !
  1. Case Cooler Master Stacker 810 Full Tower
    Por kevinr en el foro Equipo de Computo
    Último mensaje: 13 June 2012, 05:40 PM
  2. Case Cooler Master Stacker 810 Full Tower
    Último mensaje: 19 April 2012, 02:21 PM
  3. Full Tower Case: Cooler Master
    Por Red Sun´s en el foro Equipo de Computo
    Último mensaje: 7 December 2010, 11:52 AM
  4. Alienware Predator Full Tower Case
    Por computin en el foro Archivo 2002 - 2011
    Último mensaje: 17 July 2009, 11:20 AM
  5. COMPRO CASE FULL TOWER....
    Por kampos16 en el foro Archivo 2002 - 2011
    Último mensaje: 18 May 2009, 09:35 AM
